hole shot bog problem
jscharphorn
Right but if its .060" squish now then that might be your problem. Like if its set up for a .012 base and has a .020 instead. It wont have the torq to get out of the hole like your describing. You dont know till you check...
I checked the squish with thicker material and being my first time doing it I will need to have a second opinion on it, I did hold it even with the piston pin and had it in about 1.5" across the top of the piston and is what I read is from .45-.50 seems closer to the center of the piston is were it has a bigger gap.
Just curious did you use two pieces( left & right of piston)? I just went thru the same issue.
Simply dropped from .020 to a .012 base gasket. Squish dropped accordingly and bike runs as it should now. Fucking amazing :) Like a new bike.
Good luck. I hope you figure it out .
Troy
