joshuamstevens Posted June 1, 2015 Report Share Posted June 1, 2015 Banshee will run for 10 minutes then slowly loses power and dies. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted June 1, 2015 Report Share Posted June 1, 2015 Are you too stupid to even post this where it belongs? Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted June 1, 2015 Report Share Posted June 1, 2015 you`ll prolly get some worthless answers since everybody is a fucking retard lol 1 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 1, 2015 Report Share Posted June 1, 2015 I think your tire pressure is off. Had this problem with my bike. -check pressure with low pressure gauge -pump them all up to 50psi to make sure bead is tight - add slime with the air can, not the squeeze bottle(very important!) -get tires to around 65-70psi -test ride - if the bike still pulls left I'd check the voltage regulator. 1 Quote Link to comment Share on other sites More sharing options...
dankengineering Posted June 1, 2015 Report Share Posted June 1, 2015 I think your tire pressure is off. Had this problem with my bike. -check pressure with low pressure gauge -pump them all up to 50psi to make sure bead is tight - add slime with the air can, not the squeeze bottle(very important!) -get tires to around 65-70psi -test ride - if the bike still pulls left I'd check the voltage regulator. Coudlnt have had a better answer. Well said. sent from somewhere Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 1, 2015 Report Share Posted June 1, 2015 I would guess you overheated to stator leads again , might wanna up the guage and use fuse able link cable. On the real when it bogs down and dies does the spark get weaker Quote Link to comment Share on other sites More sharing options...
