I had a flooding issue with my stock carbs, so I tore them apart for cleaning, inspection and adjustment. There is a small tube running from the carb body down into the bowl that is missing from my right carb. Can i buy this somewhere, or am i going to have to replace the carb? Thanks. The right one is still pouring gasoline, the left is good. I set the floats at 21.25 mm, without the gasket.
Now i understand what the tube is for. That must be where the choke draws it's fuel. Awesome. O ring, needle and seat "looked"fine, but they'll get replaced anyway. P. S, the dummy never upped the pilot jets when they put the pipes, filter and cages on. Still 25s.
