zillakilla02 Posted May 23, 2015 Author Report Share Posted May 23, 2015 I got the float set exactly right with measuring tonight and I got it to start but it's EXTREMELY lean like no smoke at all coming out exhaust it must be because it was jetted for the slides being backwards and now it's way off. I must need to go bigger on the pilot but do I need a bigger main too? Quote Link to comment Share on other sites More sharing options...
zillakilla02 Posted May 23, 2015 Author Report Share Posted May 23, 2015 Back the tang off a little when the float is horizontal the needle should seat with the bottom of the black nipple so its not giving alot of pressure onthe springSo I turned the slides around backwards for shits and giggles and it fires right up and runs rich but it runs. ... wtf!!! When I originally took it apart the slides were backwards and the needle clip was on the 2nd position from top. I moved it to the middle. So now it's running more rich than when I first got the quad. Man the guy that had this was a knob!! So now where do I go from here? Obviously put slides the way they are supposed to be but if I go bigger with my pilot should that solve my problem? Or do I need to go richer with the needle since it's so lean with the slides the correct way?? Thanks alot Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 23, 2015 Report Share Posted May 23, 2015 Id go middle clip with 27.5 pilots and see what she does Do your slide run when its like this or no Quote Link to comment Share on other sites More sharing options...
zillakilla02 Posted May 23, 2015 Author Report Share Posted May 23, 2015 It wouldn't run until I moved the needle all the way down to the bottom clip. I can't believe the difference that made tho just moving the needle it went from not starting to sounding pretty damn good. I think it's a bit lean yet tho Quote Link to comment Share on other sites More sharing options...
zillakilla02 Posted May 23, 2015 Author Report Share Posted May 23, 2015 Id go middle clip with 27.5 pilots and see what she does Do your slide run when its like this or no But yes it will run with the slides the correct way now. I think the bigger pilot will put it right on Quote Link to comment Share on other sites More sharing options...
