bluebanshee7 Posted May 22, 2015 Report Share Posted May 22, 2015 Okay so I just got my shee and rode it twice. I fried up my lower piston bearing and did some damage to my piston, cool head and sleeve. I'm pretty sure it wasn't tuned well and was running real lean. Here's what I'm working with.. FMF fatty exhaust .5 bore cool head Timing plate set at 0 boost bottle I have my motor almost ready to split just waiting on the flywheel and clucth tool to come in. I've done loads of research about the motor, just not 100 percent sure what I would need to rebuild plus what to replace while I'm in there? Also the head that the piston fried on put a hairline crack in the sleeve by the little windows in the middle of the Head. Clearly I need to replace the sleeve but how do I got about doing so? Ordering new one? measuring it? So all I'm all I plan on changing bearings, gaskets, pistons and new sleeve in head. Is there anything else I should change out? I don't have the motor open yet so I can't tell if anything else broke yet. Thanks Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 22, 2015 Report Share Posted May 22, 2015 Should have done a leakdown test. Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 22, 2015 Report Share Posted May 22, 2015 Post pics first then order a clymer manual and then i would call a site sponsor tell em whats goin on and they will hook you up Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 22, 2015 Report Share Posted May 22, 2015 Check your carb jets too Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 22, 2015 Report Share Posted May 22, 2015 it wont be just your piston that got fucked, everything in the bottom end took that deto, even if it feels ok and specs out all the bearings might as well been hit with a sledge hammer, that cranks life has been shortened drastically 1 Quote Link to comment Share on other sites More sharing options...
registered user Posted May 22, 2015 Report Share Posted May 22, 2015 call a site sponsor. from now on that will be my response to every question. why wont my handle bars tighten, call a site sponsor. why wont my tires pump up, call a site sponsor. how do i adjust my chain, call a site sponsor. my gas cap fell off, fuck it call a site sponsor Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted May 22, 2015 Author Report Share Posted May 22, 2015 call a site sponsor. from now on that will be my response to every question. why wont my handle bars tighten, call a site sponsor. why wont my tires pump up, call a site sponsor. how do i adjust my chain, call a site sponsor. my gas cap fell off, fuck it call a site sponsor New to banshees. What's a site sponsor? And I just call and tell them my problem and they will walk me through what I need to do? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 22, 2015 Report Share Posted May 22, 2015 New to banshees. What's a site sponsor? And I just call and tell them my problem and they will walk me through what I need to do? http://www.bansheehq.com/bansheehq-sponsors/ If you are mechanical as a rubber spoon, send engine, wait, pay, get new engine. By some of your descriptions "hairline crack in the sleeve by the little windows in the middle of the Head". What the fuck does that even mean? So, what do you think you are capable of doing? BTW, get rid of that fucking boost bottle, odds are great that it caused your problem. To bad you didn't know enough to leak test before you tore it apart. 4 Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted May 22, 2015 Author Report Share Posted May 22, 2015 http://www.bansheehq.com/bansheehq-sponsors/ If you are mechanical as a rubber spoon, send engine, wait, pay, get new engine. By some of your descriptions "hairline crack in the sleeve by the little windows in the middle of the Head". What the fuck does that even mean? So, what do you think you are capable of doing? BTW, get rid of that fucking boost bottle, odds are great that it caused your problem. To bad you didn't know enough to leak test before you tore it apart. You didn't answer any of my questions so gtfo Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted May 22, 2015 Report Share Posted May 22, 2015 You didn't answer any of my questions so gtfoYou didn't provide pix or read the "how to" walk throughs...... gtfo. Or..... call redlineracing.biz or fast racing, explain damage, order all the parts needed from them. Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted May 22, 2015 Author Report Share Posted May 22, 2015 You didn't provide pix or read the "how to" walk throughs...... gtfo. Or..... call redlineracing.biz or fast racing, explain damage, order all the parts needed from them. Have pics just trying to get them up and thanks I'll give them a call Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted May 22, 2015 Report Share Posted May 22, 2015 Have pics just trying to get them up and thanks I'll give them a callNo problem. if the crack is in the sleeves, you will have a few decisions to make Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 22, 2015 Report Share Posted May 22, 2015 if you scroll down the the page a crank rebuild, true and weld from F.A.S.T should be under 2hundo not sure about turn around though http://www.farmandsandtoys.com/services.asp Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 22, 2015 Report Share Posted May 22, 2015 call a site sponsor. from now on that will be my response to every question. why wont my handle bars tighten, call a site sponsor. why wont my tires pump up, call a site sponsor. how do i adjust my chain, call a site sponsor. my gas cap fell off, fuck it call a site sponsor good idea since youre a fuckwit anyway Quote Link to comment Share on other sites More sharing options...
registered user Posted May 22, 2015 Report Share Posted May 22, 2015 just trying to fit around here with the rest of the sheep. seems theres hardly even any parts changers left anymore. just send it off to a sponsor now a days. how sad 1 Quote Link to comment Share on other sites More sharing options...
