zillakilla02 Posted May 21, 2015 Report Posted May 21, 2015 So I've been having some issues with my stock carbs leaking out the overflow. I tried adjusting the floats and got one to stop but then the other leaked. I decided to pick up some new float needles and tried again. One of them still leaked so after a bunch of adjusting I got them to not leak but I'm worried they aren't set perfect. I'm getting a big air bubble in my main fuel line coming out of tank. I've read the correct measurement is like .8 to .88 inches but from where to where do you measure?? Quote
hoppedupandcutdown Posted May 21, 2015 Report Posted May 21, 2015 21mm from the carb body WITHOUT a gasket to the top of the float. Just when it barely touches the valve. http://www.dfn.com/agservices/jetfaq.html 1 Quote
Larry's Shee Posted May 22, 2015 Report Posted May 22, 2015 Might need new O-ring on outside of needle valve seat to stop the leaking. New needle is a good start. Quote
