Spark plugs coming out
I my having problems with my plugs coming out.  I am 4 degrees advanced timing and 18cc domes.  Something isn't right though, I thought I would be have much higher compression then 140PSI in each cylinder.  Would my altitude of 2165' have anything to do with that low compression.  Everywhere I have read, it says detonation is probably the main cause for this.  The 18cc domes I have are just scribed in the side, where the 23cc domes I have are stamped.  This makes me weary of the 18cc domes.  I took the cool head off last night and everything looks good, no pitting or internal damage.
Any suggestions or guidance would be greatly appreciated. Thanks.
Edited by stoopidfast
plugs don't just back out.
Yes, they do just back out.  I know they are not supposed to.  I am trying to figure the issue before something expensive happens.  I am not sure if it is detonation or some other issue...
Detonation backs plugs out. Ditch those 18cc domes asap.
Which size ahould I be running?  I am surprised at my low compression with those domes.  Do I want to go higher or lower compression?
You said you got 140psi per cylinder, I suggest trying another compression tester first of all. Do you have any porting?
this. Its not uncommon for cheap compression testers to be misleading. Ive had brand new ones,(junk) read completely off the wall.
Yes, I have a KICK ASS quite aggressive port job from Kevin @ Herr Jugs Racing.  I will buy a better compression tester.  The Canadian Tire one I have is quite old.
Thanks.
