going 4 mil.
Im building a trail bike and am looking to go with a 4 mil stroker crank. The current motor setup is as follows:
Hjr dune/play port 65mm bore
Stock head milled down
Vforce 4 reeds
Timing plate set to +4
T5 pipes
The motor has about 10hrs on it. With new seals and bearings in bottom end. Top end is the same. Had fresh bore and hone when i got the bike.
My qestion is, what parts will i need to swap to a 4 mil? Im probably going to run the spacer plate because i will hopefully be going to a serval motor some day.
Any help would be awesome.
Thanks bansheehp. Ive never really messed with stroker motors before to know all of the necessitys.
So when you say pistons, head, and domes, im guessing this is for the added 4mm of stroke? I thought that the vitos spacer plate was designed to raise the port timing, the dome clearance etc. to be able to run the crank without further modifications? Please correct me if im wrong, the only knowledge im going by is from reading online (havent contacted a builder yet to fully understand the process)
Or just go ahead & get that serval or cub instead of dumping more cash in stock cylinders. :)
I really thought about it haha. But i figured if i put around 1500 in it now, i can finish out this season and by the first of the year my truck will be paid off. So ill be saving 400$ a month that will go towards a serval motor.
