bored?
the piston didnt fry magically, your going to burn another one up if dont you figure out why
My carbs aren't synced that's why it fried I think. I just got my shee and don't know much about the motor, still learing. I'm ordering a carb sync tool too. Just need to figure out my piston situation.
Piston situation isn't due to carb sync. Build a leak down tester before going any further. 2nd, buy or download a Clymer manual.
It sounds like your trying to order one piston. Is that what your doing?
Are you just going to throw a new piston in and call it good?
Not at all, i want to do everything I need to do to make my quad running correctly. I just have little knowledge on what I should do first And what other stuff I need to do to get it back to normal.
I'd rather not deal with all the upgrades so would I be able to buy stock parts and put it back to stock? Or are there problems going that route too?
upgrades? you need you cylinders inspected. iff they need to be bored again. if your crank suffered damage, head, crank seals. its not just slap in pistons and run.
you still don't know why this happened. that's why a leak down test is crucial at this point. itll give you an idea of what possibly happened.
  • Like 1
As sheerider said man youll be pissing up wind if you dont know why it melted down first..but you need to the leak down do some research you can make it 20 mins with about 60 bucks
I'm actually making it as we speak. I took my coolhead off already tho Can I put It back on and do the test still? And one of the small o-rings that go around the studs was busted. Will that cause a leak?
