lowidenfast Posted May 21, 2015 Author Report Share Posted May 21, 2015 http://www.amazon.com/gp/cart/view.html/ref=nav_cart <-- look right? If any vendors sell these comparably priced, I'd rather support them. Quote Link to comment Share on other sites More sharing options...
lowidenfast Posted May 21, 2015 Author Report Share Posted May 21, 2015 Thanks again Zilla, looks like our messages crossed paths. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 21, 2015 Report Share Posted May 21, 2015 (edited) I wouldn't waste your time running outerwears on a foam filter. The sticky filter oil will transfer to the outerwear and since the outerwear is a fine mesh screen all the dirt will collect on it and plug up. Foam filters are progressive filters. They start out coarse on the surface and get finer the deeper you get in to them. That way most of the dirt is trapped on the outer layer and it will still allow air to flow though and not plug up. A plugged up outerwear on the surface is just going to choke your banshee. Make sure to oil all layers of a foam filter. If you don't oil the outer most layer you might as well not even have it on there because dirt will go right through it. Edited May 21, 2015 by jbooker82 Quote Link to comment Share on other sites More sharing options...
lowidenfast Posted May 21, 2015 Author Report Share Posted May 21, 2015 Thanks jbooker. What about 4" vs 6" filters? I run the 4" K&N's w/ outerwears currently and jetting is really good. If I ran a 6" foam filter, would I potentially need larger jets? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 21, 2015 Report Share Posted May 21, 2015 If you haven't ordered them yet I would get the UP4182ST they come with the red coarse outer layer. http://www.unifilter.com/clamp-on/ Quote Link to comment Share on other sites More sharing options...
lowidenfast Posted May 21, 2015 Author Report Share Posted May 21, 2015 I haven't, I'm eye-balling those and the UP6182ST. Summit can ship either of them to store for free. I live right beside their GA location Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 21, 2015 Report Share Posted May 21, 2015 Thanks jbooker. What about 4" vs 6" filters? I run the 4" K&N's w/ outerwears currently and jetting is really good. If I ran a 6" foam filter, would I potentially need larger jets? I wouldn't think so if your current filters are not restricting air flow. In really dirty environments the more filter area you can obtain the better. If you get longer foam you might need an angled filter base / flange. I couldn't tell you about that with stock carbs because I haven't ever ran them. I use 10 deg K&N's but thats with 33mm PWK's and an angled one piece boss billet intake. Quote Link to comment Share on other sites More sharing options...
lowidenfast Posted May 21, 2015 Author Report Share Posted May 21, 2015 the 6" I'm looking at are angled. The part # changes to UP6182AST for the angled ones. Here is a link to them although I'd prob order through Summit so I can avoid shipping and return them if they didn't work for any reason. They don't ask questions http://www.amazon.com/Uni-2-Stage-Angle-Pod-Filter/dp/B001KO6KS6 Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 21, 2015 Report Share Posted May 21, 2015 Yea or order one of each then see wich one fits better. The nice thing about foam is that it isnt stiff like a K&N so you can get away with some miss alignment. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 21, 2015 Report Share Posted May 21, 2015 the 6" I'm looking at are angled. The part # changes to UP6182AST for the angled ones. Here is a link to them although I'd prob order through Summit so I can avoid shipping and return them if they didn't work for any reason. They don't ask questions http://www.amazon.com/Uni-2-Stage-Angle-Pod-Filter/dp/B001KO6KS6 Angled is gonna be much nicer. Quote Link to comment Share on other sites More sharing options...
special06shee Posted June 1, 2015 Report Share Posted June 1, 2015 In any real dusty environment your gonna have to clean ANY filter ever ride or two. The coal region is the worst place to ride as far as dust/dirt. Uni filter are far superior to k&n for protection in fine dusty shit. I recently been using a s&b filter with s&b oil on my turbo bike with good results thus far. But first sign of any dirt getting past, its in the garbage and back to uni. update. My s&b filter are in the garbage. Back to uni's. Only filter that seems to work in the coal. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 1, 2015 Report Share Posted June 1, 2015 What uni filters are you using? Mine clogged up in a few hours to the point my bike wouldn't idle. The dirt didn't get through, but it just turned to mud on the filter. Quote Link to comment Share on other sites More sharing options...
special06shee Posted June 1, 2015 Report Share Posted June 1, 2015 What uni filters are you using? Mine clogged up in a few hours to the point my bike wouldn't idle. The dirt didn't get through, but it just turned to mud on the filter. stage 2 with outterwear. Never had a problem with getting clogged up. But i clean my shit ever ride or two. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 1, 2015 Report Share Posted June 1, 2015 stage 2 with outterwear. Never had a problem with getting clogged up. But i clean my shit ever ride or two. Okay I'm gonna give them a shot. I ordered those shit durablue from Dave at east coast and sold them the same day I got them because they weren't even close to fitting my carbs. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
special06shee Posted June 1, 2015 Report Share Posted June 1, 2015 Those filters usually come with a reducer. The filter without reducer/bushing are meant for like a 54mm carb. Those filter bodies are also WAY bigger then the uni's. Quote Link to comment Share on other sites More sharing options...
