power to brand new plugs. no spark
Well basically I had no spark and went through the whole electrical system already triple tested everything works problem was shitty ground from ignition coil where it mounts to the frame. I now have about 20 v power between the 2 spark plug leads and bought brand new plugs. Poured a little gas down cylinders to see if she'd turn over a little bit and it did. Put gas tank on hooked up fuel line kicked it over and nothin...took tank off still no spark retested for power still had 20 v power but no spark??
