ryguy27 Posted May 12, 2015 Report Share Posted May 12, 2015 I just got done a full rebuild, hot rods crank all new gaskets cylinders bored and honed 64.25. Leak down test was good after replacing intakes with new upp intakes and boots. Carbs are keihin 34 pj . Pd cool head 22cc domes. Fired up on 3rd kick . Idled great, my only concern is that the left pipe (stator side) was running a lot colder than the right ( clutch side ) . Slides are in correct and adjusted. Anyone have suggestions as to what would cause this? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 12, 2015 Report Share Posted May 12, 2015 Did you synch carbs with a tool? Did you ohm the plug caps? Check coil? It's hard to hear a misfire on a banshee Quote Link to comment Share on other sites More sharing options...
