TurnerBanshee Posted May 10, 2015 Report Share Posted May 10, 2015 I have a doubt and is if this thing working really good or is pure bullshit? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 10, 2015 Report Share Posted May 10, 2015 Unless you want to cut a huge hole in your plastics there not worth it. Or you have fullbores. A tto will be your best bet. Quote Link to comment Share on other sites More sharing options...
TurnerBanshee Posted May 10, 2015 Author Report Share Posted May 10, 2015 Got it Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted May 10, 2015 Report Share Posted May 10, 2015 If you have a bigger motor and have fullbores then it could be useful. I use a different one then pictured on my 10dm trail bike and it's accurate. When I had laker plastics on it I was able to see the part that was important (200+ range) are you sure that will definitely fit on the radiator? Seems kind of pointless to me since it only goes to 200 Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted May 10, 2015 Report Share Posted May 10, 2015 If you have a bigger motor and have fullbores then it could be useful. I use a different one then pictured on my 10dm trail bike and it's accurate. When I had laker plastics on it I was able to see the part that was important (200+ range) are you sure that will definitely fit on the radiator? Seems kind of pointless to me since it only goes to 200It's in Celsius. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted May 10, 2015 Report Share Posted May 10, 2015 It's in Celsius.Ahh good eye. Ha! Yea I don't use Celsius. Any idea if it will fit the radiator correctly? Reason I ask is I'm sure they make one in Fahrenheit Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted May 10, 2015 Report Share Posted May 10, 2015 Ahh good eye. Ha! Yea I don't use Celsius. Any idea if it will fit the radiator correctly? Reason I ask is I'm sure they make one in Fahrenheit Sent from my iPhone using Tapatalk Me either lol, I had to do a double take. Idk about fitment though, this is the first I've actually seen them. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted May 10, 2015 Report Share Posted May 10, 2015 I use a import thermocap made by mr gasket. It's the 13psi one. Make sure it's the import one. It's a little tight when putting them on but it works. What motor is this for anyway? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
camp0429 Posted May 10, 2015 Report Share Posted May 10, 2015 I use a import thermocap made by mr gasket. It's the 13psi one. Make sure it's the import one. It's a little tight when putting them on but it works. What motor is this for anyway? Sent from my iPhone using Tapatalk I have this one also. I thought it was 16psi. Its about done though it's startin to let coolant out the overflow under a hard pull, i switched with back to the stock Quote Link to comment Share on other sites More sharing options...
camp0429 Posted May 10, 2015 Report Share Posted May 10, 2015 ^^supposed to say switched out with stock cap Quote Link to comment Share on other sites More sharing options...
TurnerBanshee Posted May 13, 2015 Author Report Share Posted May 13, 2015 My banshee only mod is FMF pipes and silencer stock bore, I thinking use for a trail riding and buy mr gasket is way better than temp cap that was I post first, but with this setup of my banshee I really need this? the banshee has stick plastics Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 13, 2015 Report Share Posted May 13, 2015 I ran the MR Gasket brand 16psi cap and it lasted all of 3 rides before crapping out. That thing looks even cheaper... But give it a go and see if it stays accurate. It's only a few bucks right? Can't hurt to test it out if it's cheap. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted May 13, 2015 Report Share Posted May 13, 2015 Hmm mine seems to be holding up fine. I'm using the 13psi one. I'm on my 2nd one. First one lasted a long time but eventually crapped out. Quote Link to comment Share on other sites More sharing options...
camp0429 Posted May 13, 2015 Report Share Posted May 13, 2015 Ive got several decent rides with mine, i had a head gasket fail and was pressurizing the cooling system several weeks ago, so i dont know if that had anything to do with it crappin out or not. The spring and seal all seem ok Quote Link to comment Share on other sites More sharing options...
