blackedout96 Posted May 10, 2015 Report Share Posted May 10, 2015 I've been scavenging for time to build this quad, but it's just time to throw in the towel. I've built several before, but we have a 9 month old and the old days of being able to spend a few hours in the garage every night are gone. Many of these parts are brand new, still in the box/wrapper. If it's listed as new, it literally has never been used. PM me through here or call/text 574-292-8906 Interested in something and don't see a pic, let me know and I'll get one sent asap. **All prices are + shipping and PayPal fees** ***This is a complete quad. If you need something that you don't see below, just ask. I'll add sold items below so you know it's gone*** -Complete 720 motor... Barker HV port head with +1 valves. I did not have the porting done myself, but It did get a valve job before assembling as it did not pass a pressure test. ARP Head Studs, Stage III Hotcam, new OEM cam chain, new 102mm 11:1 CP stroker piston, +4 Hotrods crank, DriveLine HD clutches, new L&A one way. cylinder bore is brand new, cylinder and head were both bead blasted when the bore and valve job were done. I have not had time to install and run the motor, but it was built right. By profession I am a powersports mechanic and am very anal about engine builds. $2000 -39mm FCR's, just went through and cleaned Sold -New Monster duals, black cans, black caps, stainless pipes. With quiet cores. $650 -New Elka Stage 3 shocks, front and rear. Built for 200lb rider, +2 LT a arms and +4 swingarm. **this price does not include the arms or swinger, this is just stating what the shocks were built to be used with** $700 -New Alba +2 LT or ST a arms $300 -New LSR +4 swingarm with new billet carrier and caliper plate. Has skid plate tabs. Gloss black. $550 -New EK MVXZ 120 Link chain $110 -Durablue X33 Eliminator Axle. It's black. Not sure if it was painted or powdercoated. $300 -GYTR Nerfs. Not new, but clean $100 -New Houser +1 steering stem with 1 1/8 a/v clamp. $275 -New ASV C6 clutch and brake lever set with Pro clutch perch. Sold -Skat-Trak 21x12x8 7 paddle extreme rears and Sand Star fronts. All on ITP wheels. $300 -Stock dunlop tires on stock rims, rims are clean and tires have good tread. These radial rears are actually my favorite dirt tire, really hook well. $150 -New Streamline steering stabilizer. Black. $125 -New Pro-Taper Contour ATV Mid bars. Black. $50 -New ODI rogue lock-on grips. Black w/ silver clamps. $20 -New Dr.D. Reverse lever relocator. $75 -Oversized oil tank. $50 -Front hubs with new bearings and seals. $100 -Titled Frame. Straight. Painted black. Worn through or flaking off in spots. I was going to have it pc'd. $175 -New airbox eliminator bracket with DT1 foam filters and all hardware. $100 -Stock headlights, clean, no broken tabs. $125 Complete set of ASV C6 levers with dust covers and C6 Pro clutch perch. Dr.D reverse relocator New Streamline stabilizer New Houser +1 stem w/ antivibe 1 1/8 clamp New braided brake line for +4 swinger The Mill Quote Link to comment Share on other sites More sharing options...
blackedout96 Posted May 10, 2015 Author Report Share Posted May 10, 2015 New set of Barker duals. Black cans, black caps, stainless pipes and they come with quiet cores. Packaged nicely, would rather not unwrap them. New set of front and rear Elka stg 3's... again would rather not unwrap them. New +4 Lonester swinger Quote Link to comment Share on other sites More sharing options...
blackedout96 Posted May 10, 2015 Author Report Share Posted May 10, 2015 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 10, 2015 Report Share Posted May 10, 2015 What is the lug pattern on the rims? Same as banshee? Quote Link to comment Share on other sites More sharing options...
trx510r Posted May 10, 2015 Report Share Posted May 10, 2015 Ill take the grips pm me ur paypal addy Quote Link to comment Share on other sites More sharing options...
blackedout96 Posted May 10, 2015 Author Report Share Posted May 10, 2015 What is the lug pattern on the rims? Same as banshee? Yes they're the same. Quote Link to comment Share on other sites More sharing options...
blackedout96 Posted May 10, 2015 Author Report Share Posted May 10, 2015 Ill take the grips pm me ur paypal addy Sent Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 10, 2015 Report Share Posted May 10, 2015 So is it 150 for all 4 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
trx510r Posted May 10, 2015 Report Share Posted May 10, 2015 Ill take the grips pm me ur paypal addy Nm his prices are Whack ffs Quote Link to comment Share on other sites More sharing options...
blackedout96 Posted May 10, 2015 Author Report Share Posted May 10, 2015 So is it 150 for all 4 Sent from my iPhone using Tapatalk + shipping, yes Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 11, 2015 Report Share Posted May 11, 2015 Is that a 7 or 11 way stablizer Quote Link to comment Share on other sites More sharing options...
blackedout96 Posted May 11, 2015 Author Report Share Posted May 11, 2015 Is that a 7 or 11 way stablizer11 Quote Link to comment Share on other sites More sharing options...
