crazysteve50 Posted May 8, 2015 Report Share Posted May 8, 2015 Just found out this stud looks to be cut. Repairable? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
camp0429 Posted May 8, 2015 Report Share Posted May 8, 2015 Remove it and replace stud Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 8, 2015 Report Share Posted May 8, 2015 Take 2 head nuts thread one on upside down then take another and thread it on regular...the flat sides should be tight together then take 2 wrenches put on each nut and break it loose Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 8, 2015 Report Share Posted May 8, 2015 Take 2 head nuts thread one on upside down then take another and thread it on regular...the flat sides should be tight together then take 2 wrenches put on each nut and break it looseNot enough room for that. You can try a stud extractor. But since your not gonna reuse it clamp that fucker with some vise grips. PB blaster and heat will help also. Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 8, 2015 Report Share Posted May 8, 2015 It think itll work but if not grip the shit out of it Quote Link to comment Share on other sites More sharing options...
registered user Posted May 9, 2015 Report Share Posted May 9, 2015 some of them studs like in the cylinder are a goofy size. 6mm extractor is to small and 8mm is to big. american size extractor may work. can rent em from autozone for free Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted May 9, 2015 Report Share Posted May 9, 2015 http://www.amazon.com/Titan-Stud-Puller-Drive-Model/dp/B00265M8N4 Quote Link to comment Share on other sites More sharing options...
