Full Throttle
Back the idle crews all the way out, adjust cable ferrel (top of slide, cable goes through) until both slides bottom out, then snug them up until there is no slack. Pull on individual cable to check slack.
At this point there should be very little gap between flat bottom side of slide and bottom of carb throat.
Now sync them. Either by eye or feel (better yet sync gauge). They should rise at exactly the same time. Either loosen or tighten one, or both , cables at carb cap.
Now you can set idle screws. From the screw barely touching the slide turn each screw the same amount to get desired idle speed. This is presuming that air screws are set correctly on both carbs.
If I described this wrong, lick my balls and do a better job than me and help him out.
If you had a Clymers manual or the pdf , you would be riding by now
  • Like 1
Step to breaking in new motor
Start, listen for noise, short ride, retorque, top off, and let her rip
Wonder how many builder strap brand new motor in bikes and do 6th gear wot dyno pulls with in first 1/2 of running.
  • Like 3
lol, last pic posted, left carb was close and right too high.  for future reference, 3/16" is starting point and will be high idle.  lower to a good idle once warmed up.  break-in.  let it warm up at idle with some blipping 2x.  retorque.  do some plug chop runs, and let cool and retorque head.  broke in and done.
  • Like 1
