jeff n Posted May 6, 2015 Report Share Posted May 6, 2015 I just picked up a 2000 Shee with a vitos 4mil crank with spacer plate, vitos ported.080 over pistons, pro desigh cool head and intake, stock carbs, Toomey t5's, k&n pods, boysen reeds, stock cages, no porting, no port match. Carbs are out of sync and netting is way off. I put it in the shop today and am having trail/play port, port match, carbs synced and dyno tuned. What kind of dyno numbers should I expect? Quote Link to comment Share on other sites More sharing options...
okbeast Posted May 6, 2015 Report Share Posted May 6, 2015 What shop? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted May 6, 2015 Report Share Posted May 6, 2015 Ask the people you dropped it off with. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 6, 2015 Report Share Posted May 6, 2015 high 60`s hopefully closer to 70 Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted May 6, 2015 Report Share Posted May 6, 2015 30hp on one dyno 115.3 on another. dyno shmyno would be close to a 450 dirt bike, dirtbike would prolly just pull away Quote Link to comment Share on other sites More sharing options...
jeff n Posted May 6, 2015 Author Report Share Posted May 6, 2015 The shop is Jsr in Wichita. If I only asked the shop doing work, how would I know if I'm getting the whole truth. I believe John is honest and does good work but I also believe that it is a good idea to get more than one opinion. Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted May 6, 2015 Report Share Posted May 6, 2015 So what did he tell you.. We want the whole story Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 6, 2015 Report Share Posted May 6, 2015 Should have asked if it was worth it to drop coin into 80 over jugs. 3 Quote Link to comment Share on other sites More sharing options...
jeff n Posted May 6, 2015 Author Report Share Posted May 6, 2015 I haven't asked jsr for hp estimate yet. Because the carbs are so far out of wack they're checking a bunch of stuff before they start the rest of work. I was hoping for around 70hp. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 6, 2015 Report Share Posted May 6, 2015 Jar knows his shit , and has a decent engine program Quote Link to comment Share on other sites More sharing options...
jeff n Posted May 6, 2015 Author Report Share Posted May 6, 2015 What about that 80 over comment? Is that as far as they can go before they need replaced? I got a very good deal on the bike and John is giving me a good deal on the work being done. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 6, 2015 Report Share Posted May 6, 2015 I don't worry much about bore size usually. I have motors last years without needing a bore. If you use a compression guage to monitor your ring life and replace as needed it can last s long time. Obviously you need to make sure tune is correct carbs are always clean , and a good ear for problems and you'll be fine. Don't be that guy that thinks it clear itself out if it's not running properly. Quote Link to comment Share on other sites More sharing options...
jeff n Posted May 6, 2015 Author Report Share Posted May 6, 2015 When the jugs hit the end, can they be resleeved or do they have to be replaced? Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 6, 2015 Report Share Posted May 6, 2015 Im not sure about 4 mils but if they have that niklesil or what ever its call on the inside but those cant be sleeved i dont think but you should be able to sleeve it if not but im not a 4 mil expert Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted May 6, 2015 Report Share Posted May 6, 2015 If they are stock just with average port work more often than not it is more economical to just buy new cylds and have them ported. Quote Link to comment Share on other sites More sharing options...
