banshee_rider95 Posted November 26, 2003 Report Share Posted November 26, 2003 The other day when i was riding i went to shut the motor off using the kill switch like i always do, well for some reason it wouldnt work. So i just turned the key off. I went to start it again and it started just fine but the kill switch still didnt work. I drove home and parked it in the yard to clean it up. I tried to start it up again and it wouldnt. I got pissed off and but it in my garage. Today i put new new plugs in and i cleaned the airfilter. Finally after like 15 mins it started but i couldnt give it any gas without it boggin down and shuting off. The right side ran fine but the left side ran like a plug was fouled After awhile i finally got it to take off in first gear so i went up the road and when i shifted it into second gear it backfired on the left side and shutoff. I called my friend and he came up. He put new plugs in it and i tryed to start it and it still wouldnt start... So what does it sound like it is? I have the TORS disconnected and the parking brake if that helps If u guys have any clues let me know... im lost ThANks Quote Link to comment Share on other sites More sharing options...
banshee_rider95 Posted November 26, 2003 Author Report Share Posted November 26, 2003 anybody??? Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted November 26, 2003 Report Share Posted November 26, 2003 Ok,...so your torrs is disconnected, but you still have the parking break? Dunno if that's what you meant or not...if you still have the stock clutch perch...follow the wires off the perch down to the left side of the gas tank where there is a little plug, disconnect that plug & tape it off. Try that, if applicable. Quote Link to comment Share on other sites More sharing options...
banshee_rider95 Posted November 26, 2003 Author Report Share Posted November 26, 2003 o....i already have disconnected the parking brake before this problem, sorry to confuse u....anyother ideas? Quote Link to comment Share on other sites More sharing options...
banshee_rider95 Posted November 27, 2003 Author Report Share Posted November 27, 2003 anybody else? Quote Link to comment Share on other sites More sharing options...
speedster07 Posted November 28, 2003 Report Share Posted November 28, 2003 is the left side firing with no compression or is it not firing at all, check your rings and spark Quote Link to comment Share on other sites More sharing options...
