Topend rebuild
Ok any suggestions on what I need to do now ? I have it bored .60 over , dmc exhaust and stock air box with no lid k and n air filter . I have unpluged the little black box for the tors . I have 280 mains and 27.5 pilots . I have cleaned and replaced pretty much everything in my stock mukuni carbs exept for the choke . I have changed and tightened the choke crossover tube and moved my needle clip back to the middle position . I think that is about it other than some odds and in s . Ok so now it is starting and idleing like it is supposed to with the choke but the exhaust is getting fairly warm pretty quick . Is that a lean condition or what ?Thanks for all your help again guys !! I am recently new to 2 strokes and banshees . But I love the sound and the RIDE !!!
Sent from my SCH-R530U using Tapatalk
Ok I have a dmc exhaust , stock air box without the lid, bored .60 over with 280 mains and 27.5 pilots . I have done the leak down test . Everything holds pressure for the six minutes like it is suppose to . I have cleaned the carbs and adjusted the floats , replaced the needle seats and needle. I have deleted the boost bottle . I got it to where it will start with the choke and you can shut the choke off but you still have to give it a little gas to stay running . I took the plugs out and the one on the left is a little darker than the one on the right and they are both wet with gas . So idk ya'll tell me what you think ? I know the blackness and wet plugs are a symptom of being rich but idk what to try next . Any help or suggestions would be awesome! Thanks a million!!!
Made it through pg 2 so far :rotflmao: Will go back later. When a tread gets to the bottom of page it kinda gets lost. And I forgot what most of it was about .
I just put DMC's on my sons shee. Unported 4mil, thick head gasket, Vito's reeds, stock carbs, no TORS, K&N no lid. 300m, 30p, stock needle, middle clip, 1 1/2 air screw. About 900-1000 elev, in theMURDER MITTEN  Might still play with A/S or needle, bit unclean 1/8 - 1/4 throttle, slowly increasing.Don't notice anything just punching it. I really hate fucking with needles. If the kid says something, I'll mess with it.
Double check that slides are synced.
Edited by Larry's Shee
Sorry Larrys shee I haven't got to try that yet . I have been dealing with my old mans water line that is leaking somewhere in the 1400 ft that it runs from the meter to the house . But as soon as I can get to it I eill definitely let you all know .
If your lid is on put the 250 mains back in, your carb bodies arnt trimmed enouph for the idle screws to work properly, if I were you I would trim the carb bodies a lil more , order a vacuum guage (there cheap) then adjust idle screws til it pulls around 4-5 cfm , make sure your slides are pulling equally.
No my lid is not on yet . I didnt want to put it back on until I get it close enough to being rite because it is a bitch to get on and off .
