O/CbansheeRider Posted June 19, 2015 Report Share Posted June 19, 2015 Try kicking it four or five times slow with ignition off choke on. Then turn on ignition. See if it'll fire then. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
OutlawCM85 Posted June 19, 2015 Author Report Share Posted June 19, 2015 Thanks for all your help Larry's Shee ! It is probably going to takr me till tomorrow night to check everything that you all have told me about . I got alot of sh#t going on rite now . I will get back to you guys asap . Again thank you guys for all the help and suggestions !! Sent from my SCH-R530U using Tapatalk Quote Link to comment Share on other sites More sharing options...
OutlawCM85 Posted June 19, 2015 Author Report Share Posted June 19, 2015 The "BB" is on the front outside. It's how they plug outside of hole when drilled at factory, part of the choke/enrichment circut of carb. Not sure how it would work if both carbs had a left hand bowl. Is this the bb you are talking about ? If it is it is on the left side . So I I guess I can check that off the list . Sent from my SCH-R530U using Tapatalk Quote Link to comment Share on other sites More sharing options...
OutlawCM85 Posted June 19, 2015 Author Report Share Posted June 19, 2015 Try kicking it four or five times slow with ignition off choke on. Then turn on ignition. See if it'll fire then. Sent from my iPhone using Tapatalk Ok I did that along with taking the carbs apart and cleaning them and changing the crossover tube . She fired up and ran pretty decent with the choke on and was no longer overflowing from the one carb on the left but the exhaust got pretty warm in that little bit of time . I fill like i'm so close I can taste it ! Sent from my SCH-R530U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 20, 2015 Report Share Posted June 20, 2015 Nope, just like that but on front of bowl, that is if they are stock carbs Quote Link to comment Share on other sites More sharing options...
OutlawCM85 Posted June 20, 2015 Author Report Share Posted June 20, 2015 Sounds like you have a tors problem. In front of the left pipe should be a little black box , make sure it's unpluggedOh yea I unpluged that little black box too . Sent from my SCH-R530U using Tapatalk Quote Link to comment Share on other sites More sharing options...
OutlawCM85 Posted June 20, 2015 Author Report Share Posted June 20, 2015 Nope, just like that but on front of bowl, that is if they are stock carbsIm not sure if they are stock or not . I measured the side were the air filter goes and it is 40 mm Sent from my SCH-R530U using Tapatalk Quote Link to comment Share on other sites More sharing options...
OutlawCM85 Posted June 20, 2015 Author Report Share Posted June 20, 2015 I'm pretty sure I read somewhere that stock carbs were 37mm Sent from my SCH-R530U using Tapatalk Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted June 20, 2015 Report Share Posted June 20, 2015 I'm pretty sure I read somewhere that stock carbs were 37mm Sent from my SCH-R530U using Tapatalk Stock carbs are 26mm Quote Link to comment Share on other sites More sharing options...
OutlawCM85 Posted June 20, 2015 Author Report Share Posted June 20, 2015 Stock carbs are 26mmOk well I guess mine are 40mm mukuni's . I think as far as the whole carbs go they can only go on one way because the choke tube wont go in the other carb . If you put the left carb on the right you wouldnt be able to pull the choke. Sent from my SCH-R530U using Tapatalk Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted June 20, 2015 Report Share Posted June 20, 2015 Stock carbs and your air screw are adjusted different Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 20, 2015 Report Share Posted June 20, 2015 Im not sure if they are stock or not . I measured the side were the air filter goes and it is 40 mm Sent from my SCH-R530U using Tapatalk Have to measure inside of end that goes in boot. Plus 40mm Micunis wouldn't have a choke crossover tube. Would be individual chokes. Dare say stock carbs are the only ones you'll ever find with only one choke knob/lever (on a bangshee) Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted June 20, 2015 Report Share Posted June 20, 2015 theyre stock... but you measure the small end of the carb not the bell end for bore size. Quote Link to comment Share on other sites More sharing options...
OutlawCM85 Posted June 20, 2015 Author Report Share Posted June 20, 2015 Ok thanks now I know . I guess you learn something new every day . Sent from my SCH-R530U using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 21, 2015 Report Share Posted June 21, 2015 Stock carbs are 26mmNot on the filter side. Quote Link to comment Share on other sites More sharing options...
