willaduncan Posted May 15, 2015 Report Share Posted May 15, 2015 Actually the manual calls for 20 but most builders do 22. You can buy a torque wrench for around 100 bucks that works well enough Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Hellbroke Posted May 15, 2015 Author Report Share Posted May 15, 2015 I have them on 19 right now Quote Link to comment Share on other sites More sharing options...
willaduncan Posted May 15, 2015 Report Share Posted May 15, 2015 You can try it but I would do it right... Make sure you do a leak down Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Hellbroke Posted May 15, 2015 Author Report Share Posted May 15, 2015 Whats a leak down and I'm borrowing the right torque wrench off my brother in law to do it tomorrow night. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted May 15, 2015 Report Share Posted May 15, 2015 Do not run that quad until you do a leak down Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted May 15, 2015 Report Share Posted May 15, 2015 Block off the exhaust ports with plugs, put the above set-up in your intake, pump 6 psi into the motor and make sure it holds the pressure for 6 minutes Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Hellbroke Posted May 15, 2015 Author Report Share Posted May 15, 2015 Got everything back together and now its leaking oil bad from the casing on the left where the shifter is? Any ideas. Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 15, 2015 Report Share Posted May 15, 2015 Yup crank seal is bad on that side i bet esp if its leaking from the stator cover side Quote Link to comment Share on other sites More sharing options...
98_sheester Posted May 15, 2015 Report Share Posted May 15, 2015 Unless it passed your leak down test. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted May 15, 2015 Report Share Posted May 15, 2015 If it's where your shifter is positioned, its probably that seal. Quote Link to comment Share on other sites More sharing options...
Hellbroke Posted May 15, 2015 Author Report Share Posted May 15, 2015 This is where its leaking oil from if that helps. Quote Link to comment Share on other sites More sharing options...
Hellbroke Posted May 15, 2015 Author Report Share Posted May 15, 2015 Got her back together and it starts but as soon as it starts its just balls to the wall full throttle on its own Quote Link to comment Share on other sites More sharing options...
do-work-son Posted May 15, 2015 Report Share Posted May 15, 2015 Leak down.....or does it need to be said a few more times? 1 Quote Link to comment Share on other sites More sharing options...
willaduncan Posted May 16, 2015 Report Share Posted May 16, 2015 If it's leaking from the shifter, your shift seal is bad just replace it Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted May 16, 2015 Report Share Posted May 16, 2015 And if your idle screws aren't all the way in and your slides aren't hung.... Again leak down or you gonna be doing full rebuild Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
