323Racing Posted April 30, 2015 Report Share Posted April 30, 2015 Ok so after driving my banshee for the first time I love it! BUT I have a few problems I want to fix before I paint my frame. It is pretty much impossible to get it into neutral while its running Shifting gears is hard, you really have to force it into gear and I have a slight bog right off idle, other than that it runs amazing I heard about the pancake bearing, is this worth it? Probably going to get a new impeller and oversized radiator. Mods are .50 over vitos pistons, 22cc pro design cool head, vforce4 reeds, k&n filter kit with airbox and cover, and jetted carb. Thank! Quote Link to comment Share on other sites More sharing options...
Travis160 Posted April 30, 2015 Report Share Posted April 30, 2015 Slight bog is a carb issue.. Mine did as well took them apart cleaned and re sync.. And shifting.. If you have to forcr.it into gear you are doing more harm than good lol clutch issues.. Im sure someone with more clutch knowledge that i can she some light good luck! Quote Link to comment Share on other sites More sharing options...
Travis160 Posted April 30, 2015 Report Share Posted April 30, 2015 Oh and check your jetting vs elevation.. Dunno where you bought it but it does make a difference if you go high to low or vice versa Quote Link to comment Share on other sites More sharing options...
registered user Posted April 30, 2015 Report Share Posted April 30, 2015 on a standard trans you shouldnt need to use the clutch while shifting as long as there isnt a bunch of torq on the gear dogs. try letting off the gas just a hair then lifting the shifter. if its hard to shift no matter what, then i would almost say you may have something wrong with the drum or forks as for hard to get in nuetral while running, sounds like your basket and hub arent seperating from each other, for what ever reason. warped plates, clutch not adjusted correct, basket grooved etc Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 30, 2015 Report Share Posted April 30, 2015 What type of power is the bike making? If it's pretty well built you may need some trans work done to promote better shifting. At a minimum there are some simple bolt on items that can help. Otherwise, check ALL components for wear and properly adjust the eccentric/shift shaft. Quote Link to comment Share on other sites More sharing options...
oldskool Posted April 30, 2015 Report Share Posted April 30, 2015 Check your shift claw adjustment on star. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 1, 2015 Report Share Posted May 1, 2015 Check shift claw, ecentric screw, star tight? Thry shift shaft mod and star mod. As to bog try adjusting air screw a cunt hair if not better, go CH other way from starting point. (HINT CH is 1/16 of a turn) Quote Link to comment Share on other sites More sharing options...
323Racing Posted May 6, 2015 Author Report Share Posted May 6, 2015 What type of power is the bike making? If it's pretty well built you may need some trans work done to promote better shifting. At a minimum there are some simple bolt on items that can help. Otherwise, check ALL components for wear and properly adjust the eccentric/shift shaft. Should be making some power. Pro Design 22cc chambers .50 over vitos superstock pistons VForce 4 reeds Jetted carb FMF Fattys with FMF power core 2 silencers K&N air filter kit with airbox and lid At sea level 93 Octane 32:1 Maxima Castor 927 Maxima MTL 75w Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 7, 2015 Report Share Posted May 7, 2015 Not enouph that you can't shift ,that still a bolt on bike. Something isn't adjusted rite. Quote Link to comment Share on other sites More sharing options...
