Mike14_07 Posted April 25, 2015 Report Share Posted April 25, 2015 I took my dads banshee apart about a month ago. Got busy, now im getting ready to build the motor. I pulled all the front plastic off, exhaust, carbs, motor, cylinders and head. I found these 2 in my body box and cant figure out where they go. There are 4 of the nuts and 1of the screws. The nuts are the same size as the base and head nuts but about an 1/8" shorter. If anybody could help id greatly appreciate it Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted April 25, 2015 Report Share Posted April 25, 2015 Looks like gas tank / plastic screw Quote Link to comment Share on other sites More sharing options...
vrx46 Posted April 25, 2015 Report Share Posted April 25, 2015 Agreed Quote Link to comment Share on other sites More sharing options...
Mike14_07 Posted April 27, 2015 Author Report Share Posted April 27, 2015 Thanks guys ill check that in the morning. Any idea about the nuts? They appear to be the slightly oval locking type nuts. If that helps. This thing is in rought shape, it needed a top end job about 08-09 and sat ever since. Prolly '10 he put it out side till i picked it up a few months ago to give it an over haul Quote Link to comment Share on other sites More sharing options...
Mike14_07 Posted April 27, 2015 Author Report Share Posted April 27, 2015 Dont see a spot for a screw this size gir the tank am i missing something? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 27, 2015 Report Share Posted April 27, 2015 I think the one I had like that fit perfectly into the extra parts bucket. It's red and has an old worn out folgers sticker on it. It's usually in a gray cabinet. 1 Quote Link to comment Share on other sites More sharing options...
Rigid_Banshee Posted May 1, 2015 Report Share Posted May 1, 2015 those look to be the mounting bolts for the pickup coil on the stator plate, the nut could either be for the cylinders or the head. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 1, 2015 Report Share Posted May 1, 2015 the screw is for the throttle cover and the nut is off the flux capacitor Quote Link to comment Share on other sites More sharing options...
