ATVridinMaNiAc Posted April 21, 2016 Report Share Posted April 21, 2016 Do the beadlocks serve any real purpose? Other than keep it on the bead lol They are awesome at adding on weight from mud getting stuck in your rim. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted April 21, 2016 Report Share Posted April 21, 2016 Do the beadlocks serve any real purpose? Other than keep it on the bead lol The rim will take more of a beating without folding like a paper clip. Also, keeping the tire on the bead is kind of important? Especially when your bashing your rims and tires off of rocks. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted April 21, 2016 Report Share Posted April 21, 2016 They are awesome at adding on weight from mud getting stuck in your rim. That's weird, they do make those things called "mud plugs" for a reason. Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted April 21, 2016 Report Share Posted April 21, 2016 (edited) Edited April 21, 2016 by ATVridinMaNiAc Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted April 21, 2016 Report Share Posted April 21, 2016 That's weird, they do make those things called "mud plugs" for a reason. That is weird huh... Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 21, 2016 Report Share Posted April 21, 2016 That is weird huh...Lol. You clearly don't ride hard enough to need bead locks then Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted April 21, 2016 Report Share Posted April 21, 2016 I was just being a sarcastic smart ass you damn fools... Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 21, 2016 Report Share Posted April 21, 2016 ^ weekly genius. Quote Link to comment Share on other sites More sharing options...
Sheedawg28 Posted April 21, 2016 Author Report Share Posted April 21, 2016 I was just being a sarcastic smart ass you damn fools... I would try and use that excuse also after looking like a dit ditty 2 Quote Link to comment Share on other sites More sharing options...
Sheedawg28 Posted April 21, 2016 Author Report Share Posted April 21, 2016 Do the beadlocks serve any real purpose? Other than keep it on the bead lol So like Bennett said they definitely will take a beating a lot better than your average wheels. I've also slightly popped the bead off regular wheels from sliding into a corner and catching a fat rut which beadlocks help with. And if you think you can swap out tires quick with non bead lock wheels you should see how quick that's doable with beadlocks and only having to pop the bead off on one side. I guess I could add in here also that unlike regular wheels where if you do happen to bash the lip with a rock you can always replace the ring. I don't rock them in the front since I haven't felt it be necessary since I don't through as many tired as the rear and if I do bang the fronts up they're pretty cheap but these rolled lips on the DWT's have held up to some good sideways bands into rocks in the little trail I riding I've done with them. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted April 21, 2016 Report Share Posted April 21, 2016 So like Bennett said they definitely will take a beating a lot better than your average wheels. I've also slightly popped the bead off regular wheels from sliding into a corner and catching a fat rut which beadlocks help with. And if you think you can swap out tires quick with non bead lock wheels you should see how quick that's doable with beadlocks and only having to pop the bead off on one side. I guess I could add in here also that unlike regular wheels where if you do happen to bash the lip with a rock you can always replace the ring. I don't rock them in the front since I haven't felt it be necessary since I don't through as many tired as the rear and if I do bang the fronts up they're pretty cheap but these rolled lips on the DWT's have held up to some good sideways bands into rocks in the little trail I riding I've done with them.I'm the opposite. I fuck the fronts up more than the rear, but it's all in where/how you ride. 1 Quote Link to comment Share on other sites More sharing options...
Sheedawg28 Posted April 22, 2016 Author Report Share Posted April 22, 2016 This damn beezy for the 3rd time Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 22, 2016 Report Share Posted April 22, 2016 Eh, what is the surface of the cylinder like? Quote Link to comment Share on other sites More sharing options...
CFH87 Posted April 22, 2016 Report Share Posted April 22, 2016 Bike looks good, how you like the hjr port with the dmc pipes? Power come on fast? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 22, 2016 Report Share Posted April 22, 2016 How is changing a beadlock wheel out easier than a non beadlocks wheel? You need a bead breaker for one side anyway, so it would be WAY faster to pop the bead off both than take about 20 bolts out of oe side and have to use a bead breaker on the other side anyway. You guys obviously don't change tires enough. my rears have dual beads. Hit it with a drill and I can swap rears with rims still on bike if I wanted. Quote Link to comment Share on other sites More sharing options...
