Shee_Rookie Posted November 26, 2003 Report Posted November 26, 2003 Hey all, I just changed out my tranny fluid with some Maxima MTL 2 cycle transmisson fluid with the clutchsaver formula and what diff. I was banging through my gears yesterday and it was like butter! Just kinda curious if anyone has used this product and is as happy about it as I am? Quote
bansheelover Posted November 26, 2003 Report Posted November 26, 2003 ok this might sound retarded but isnt the engine oil u change every so often the same as transmission oil, or is there 2 different locations of these fluids, i havent changed my tranny oil but i have changed my engine oil whats the difference??? thanks Matt Quote
SyNtAxx Posted November 26, 2003 Report Posted November 26, 2003 Hello, The banshee soes not have "engine oil". The oilused to lubricate the engine is in the gas mix (pre mix). The oil in tha case is actually the transmission oil/fluid. So if you have "changed your eingine oil" you did infact change the tranny fluid....which is not red because it is really motor oil in most cases.... Nick Quote
bansheelover Posted November 27, 2003 Report Posted November 27, 2003 thats what i thot... thanks for clarifying Matt Quote
jinx44 Posted December 10, 2003 Report Posted December 10, 2003 used to run Belray gearsaver. recently switched to Motul Transovl and the differnce is night and day. SOOO much easier to find neutral. CLutch action is smoother. This will be my new oil. Quote
00BANSHEE Posted December 10, 2003 Report Posted December 10, 2003 I run Maxima MTL without any problems. I buy it by the case and change it every couple of trips. Quote
