Banshee jetting
arena314
Ok so I got an 03 banshee and the guy I got it from said it needs to be jetted bc it wasn't running right so I jetted it and tuned it and it ran perfect the only strange thing is when I was riding it and would let off the throttle it would stay at high rpms for a 5 to 10 seconds to go down to idle again but I didn't think much of it then after about 20 out of nowhere the rpms jumped like crazy and wouldn't stop climbing until I kill the engine and when I started it back up itb would do it again and again. I come to the conclusion that it may be a bad throttle cable but I really don't know. It has a tors eliminator kit so it's definitely not that. What do you think it is? Think it could be the fuel cable? Let me know. Thanks
you didn't mention what you changed the jetting to? This could be useful information if accompanied with a list of your engine mods and air filter style? Usually a maladjusted cable will raise the throttle when you turn the wheel if its too tight. More then likely jetting or an air leak. I would lean more towards an air leak if it is getting increasingly worse.
Have you taken your carbs apart lately? Its simple to look down your air box, and see if your cut outs are facing you. No you can put the wrong slides in the wrong carb, and still screw it down....just go look.
Sent from your mammy house
I just read through this. Sounds like an airlleak, could be jetting. If your slides are in wrong it will run like shit. Look everything over. Always a good idea to do a compression test, and leak down test when you buy something. Most of the time shady ass people will pass a problem off as something easy to fix. If it revs to the moon by itself, you have an airleak!
Well jetting Is out if anything your rich,I'm going air leak. I would not ride it anymore till you pressure test it there is pics all over this site about . Needs to hold 6 lbs for 6 mins accept nothing else, or think you know what's wrong with it and burn it down trying to figure it out
