kenyounot Posted April 14, 2015 Report Share Posted April 14, 2015 (edited) Whats the word you geniuses of the banshee... 28 PWKs 4 Mil Dune Port 162 Mains 50 Pilot JJH 2 Clip from top. Edited April 14, 2015 by kenyounot Quote Link to comment Share on other sites More sharing options...
kenyounot Posted April 14, 2015 Author Report Share Posted April 14, 2015 Its not brown though its like a grey tint. Quote Link to comment Share on other sites More sharing options...
kenyounot Posted April 14, 2015 Author Report Share Posted April 14, 2015 Well i started with a sawsall and ended with a dremel grinder lol. Pipes got extremely hot in that short burst like steaming Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 14, 2015 Report Share Posted April 14, 2015 I think you need just a touch more fuel. 1 Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted April 14, 2015 Report Share Posted April 14, 2015 ^^Agreed. Quote Link to comment Share on other sites More sharing options...
kenyounot Posted April 14, 2015 Author Report Share Posted April 14, 2015 Im going to chop the 165's tomorrow. If that comes back lean Im running another leak down lol. Quote Link to comment Share on other sites More sharing options...
kenyounot Posted April 14, 2015 Author Report Share Posted April 14, 2015 Should i drop a clip on the needle or go up a main Quote Link to comment Share on other sites More sharing options...
uman1030 Posted April 14, 2015 Report Share Posted April 14, 2015 Assuming you did the typical WoT pull for your plug chop then the main is what is effecting the color of your plug. And that is what you need to bump up at this point in order to dial the main jet in. Quote Link to comment Share on other sites More sharing options...
Phelps Posted April 14, 2015 Report Share Posted April 14, 2015 def too lean. Quote Link to comment Share on other sites More sharing options...
kenyounot Posted April 14, 2015 Author Report Share Posted April 14, 2015 Okay, will do the 165 chop tomorrow and report back. Thanks everyone. Quote Link to comment Share on other sites More sharing options...
kenyounot Posted April 14, 2015 Author Report Share Posted April 14, 2015 For my set up at what point in the higher jets do I start worrying about the leanness coming from somewhere else. I did a leak down before I started messing around with carbs so much and it passed. I'm at 800 ft elevation but when I ride ride down the mountain to where I ride I must drop atleast 200 ft. Quote Link to comment Share on other sites More sharing options...
Phelps Posted April 14, 2015 Report Share Posted April 14, 2015 well.... the 28's do have a strong signal so 160 do seem a little high, but on the other hand every combo wants something different. if you had stock reed cages i would say 165 would be "ballpark", but if you're running vforce typically most end up around 155. if it passed a leakdown it's possible the porting dropped some signal and it just needs more fuel. either way you're still on the lean side for sure. Quote Link to comment Share on other sites More sharing options...
kenyounot Posted April 14, 2015 Author Report Share Posted April 14, 2015 Chariot cages with boyesen reeds and a spacer to clear clutch in front of the reed cage. Quote Link to comment Share on other sites More sharing options...
Phelps Posted April 14, 2015 Report Share Posted April 14, 2015 yeah. they work ok, but don't increase signal like a vforce. you may end up a little bigger than most. i'd stay on your path. try the 165's and do another chop. Quote Link to comment Share on other sites More sharing options...
kenyounot Posted April 14, 2015 Author Report Share Posted April 14, 2015 Sounds good brotha Quote Link to comment Share on other sites More sharing options...
