SHEEMAN0415 Posted April 8, 2015 Report Share Posted April 8, 2015 My friend called me over to help hi with his banshee today, i could only stay for about an hour so we didnt get far but im going back tomorrow and was hoping you guys had some suggestions. It starts up nice but it has no balls, especially when you drive it you cant get it into the powerband. coils, plugs were good. carbs were cleaned.compression test both sides we got 115. only mod on it is a k&n filter. rest is bone stock. suggestions? thanks in advance! Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted April 8, 2015 Report Share Posted April 8, 2015 Do a leak down test... Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 8, 2015 Report Share Posted April 8, 2015 Tors or parking brake. But if he called you and you came here asking what to do, your not qualified to take on the job either. Quote Link to comment Share on other sites More sharing options...
SHEEMAN0415 Posted April 8, 2015 Author Report Share Posted April 8, 2015 Tors or parking brake. But if he called you and you came here asking what to do, your not qualified to take on the job either. im not taking on a job i was just looking to see if i could help. dont be a dick Quote Link to comment Share on other sites More sharing options...
SHEEMAN0415 Posted April 8, 2015 Author Report Share Posted April 8, 2015 and the tors is removed already Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted April 8, 2015 Report Share Posted April 8, 2015 Your friend running a k&n on stock pipes, and stock jetting? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 8, 2015 Report Share Posted April 8, 2015 Make sure it's got a bit more fuel for that filter. Also what are the temps like there? And what did the plugs look like? Same on both sides? 27.5 pilot Needle 1 clip richer 220 main at least. They should run ok down to about 100 psi in each cyl, so I'd say there is life left in it for sure. Quote Link to comment Share on other sites More sharing options...
SHEEMAN0415 Posted April 8, 2015 Author Report Share Posted April 8, 2015 Your friend running a k&n on stock pipes, and stock jetting? yes lol Quote Link to comment Share on other sites More sharing options...
SHEEMAN0415 Posted April 8, 2015 Author Report Share Posted April 8, 2015 Make sure it's got a bit more fuel for that filter. Also what are the temps like there? And what did the plugs look like? Same on both sides? 27.5 pilot Needle 1 clip richer 220 main at least. They should run ok down to about 100 psi in each cyl, so I'd say there is life left in it for sure. the temps here right noe are really moody haha. its 46 right now, it was 20 yesterday and suppose to be 50 tomorrow. i live in upstate ny. And thanks i will try the new jetting settings you gave me Quote Link to comment Share on other sites More sharing options...
SHEEMAN0415 Posted April 8, 2015 Author Report Share Posted April 8, 2015 Make sure it's got a bit more fuel for that filter. Also what are the temps like there? And what did the plugs look like? Same on both sides? 27.5 pilot Needle 1 clip richer 220 main at least. They should run ok down to about 100 psi in each cyl, so I'd say there is life left in it for sure. and yes both plugs looked the same. they looked a little dark at the tips though Quote Link to comment Share on other sites More sharing options...
