Mats Posted April 7, 2015 Report Posted April 7, 2015 Hi guys, just picked up an 08 banshee. It is all stock except for the following. I installed vforce 4 reeds, removed the tors, installed idle screws and rebuilt the stock carbs. The machine had a slight bog off idle, I could get it to go away with pulling the choke out slightly. That is why I rebuilt the carbs, did not cure the bog. 200 mains, pilots 25, needles in the middle, idle mixture screws 1.5 turns out. Do I need to change the jetting any? Stock airbox and filter and exhaust. Once it gets some rpms, it pulls strong. Quote
bigweav81 Posted April 7, 2015 Report Posted April 7, 2015 Compression test, leak down test. Vf4 reeds like a bigger pilot...at least mine did on my old set up. 1 Quote
trickedcarbine Posted April 7, 2015 Report Posted April 7, 2015 Do a 27.5 pilot and 220ish main. Quote
