cdnbanshee Posted April 6, 2015 Report Share Posted April 6, 2015 hi guys, this is my first post but i have been following this site since i got banshee this december, i have been pulling my hair out these last few days and i was hopeing someone might have some insight into what the problem might be before i spend more money guessing, i found when i am trying to sync my carbs no mater what i do i cant get them in sync with each other on the tool i got from fast. my problem carb is the left one ( choke side ) , its seem be sluggish and doesnt wanna pull air when i hit the throttle and even when i follow the gauge and put the left carb way to tight it will pull weak then all of a sudden pull hard then weak again, i recently rebuilt my top end, compression and leak down tests where good, i have rebuilt both carbs, replaced stock reeds with v force thinking my reeds where warn out, my carb boot look good and everything is tight ! my jetting is 27.5 pilots, needle 4th clip from blunt end, 320 mains ( a bit rich im sure but its been cold here in Canada ) and im at sea level, i also notice me fuel air screw doesnt seem to effect much and then when trying to sync and i rev the motor to get a reading it seem to take a while to rev back down to idle like its lean but i dont see how thats possible. this is my first banshee but i have played around with and worked on sleds and bikes all my life so i am familiar with 2 strokes. any help would be greatly appreciated, thanks in advance Quote Link to comment Share on other sites More sharing options...
cdnbanshee Posted April 6, 2015 Author Report Share Posted April 6, 2015 I also noticed the left side never really smoked as much as the right at the start, after riding it clears up and they seem the same and I have never noticed it burning tranny oil Quote Link to comment Share on other sites More sharing options...
oldskool Posted April 7, 2015 Report Share Posted April 7, 2015 Try going up on pilot and let engine warm up before making adjustments Quote Link to comment Share on other sites More sharing options...
