Mrtaterman Posted April 5, 2015 Report Share Posted April 5, 2015 Hello! First post, first time banshee owner just traded for my scrambler thursday i have a few questions 1. took it out for a ride, runs good (i think) at low end / mid. but going up a hill (dunes or sand mountain) pushing the throttle in anything from 3/4 to WOT it bogs and fall flat on its face and i have to turn around only thing other than stock is unifilters main jet is 200 (stock) and needle is 1 from the bottom. i know i need to go up on my main but how much? ride mostly at around 11,000 (little sahara, UT) 2. the chain was extremely loose, attempted to tighten but adjusters went out all the way and it was still very loose, took out a link and it was extremely tight. i bought a new quality chain and its better but still on the loose side. my upper and lower chain rollers are trashed, the upper is nearly gone, lower's bearings are grinding and worn as well. if i replaced everything with something like the: Modquad chain slider/guide set or something similar, would that tighten up the chain significantly? pictures are not working for some reason Quote Link to comment Share on other sites More sharing options...
Phelps Posted April 5, 2015 Report Share Posted April 5, 2015 wot bog (clean bog) would suggest lean. i would start with 220's with the aftermarket filters. on the chain depending on sprocket setup you may have to go with a half link. you may try new rollers and see if that helps. i just use a chain tensioner to solve the typical chain issues. 1 Quote Link to comment Share on other sites More sharing options...
Mrtaterman Posted April 5, 2015 Author Report Share Posted April 5, 2015 i forgot to mention, there is no air box at all, just filters to the carb Quote Link to comment Share on other sites More sharing options...
camp0429 Posted April 5, 2015 Report Share Posted April 5, 2015 One stock swinger you can remove some material from where the bottom bolt mounts, this will let the carrier move forward so you can run the chain you shortened. I had to shorten a chain to run a 13 tooth front and had to take about a 1/4" Quote Link to comment Share on other sites More sharing options...
camp0429 Posted April 5, 2015 Report Share Posted April 5, 2015 ^^on Quote Link to comment Share on other sites More sharing options...
Mrtaterman Posted April 5, 2015 Author Report Share Posted April 5, 2015 (edited) i think i might try the Modquad Chain Slider/Guide Set and see what happens, if not then ill use my shortened chain, the ones on there are worn down to metal, so there's basically nothing left. the other ones are just as good (bad) as this one Edited April 5, 2015 by Mrtaterman Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 6, 2015 Report Share Posted April 6, 2015 you should use new sprockets if your chain was worn that bad. I've also used 1/2 link to get the chain closer, forget what gear combo, real pisser. Quote Link to comment Share on other sites More sharing options...
Mrtaterman Posted April 6, 2015 Author Report Share Posted April 6, 2015 just checked the sprockets front is 14t rear is 40t smaller one tooth person i got it from told me the sprockets (and chain) were new, sprockets seem to be new Quote Link to comment Share on other sites More sharing options...
