iukaman Posted November 26, 2003 Report Share Posted November 26, 2003 Ok, this is basically my problem. I am riding a '98 shee in the woods at night, when i go around a corner, of course I am not revved up all the way meaning I am not getting max light output. Therefore, i cannot see around the corner. Does anyone know what would be needed to make the lights not go off immdiately like it does. I wouldn't mind even a slow 4-5 sec. drain instead of the 1/2 sec drain. I have heard there are battery kits and some people say use a cap. I need a cheaper route b/c I am a college student. Also i want to keep the weight down. Thanks Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted November 26, 2003 Report Share Posted November 26, 2003 those are basicly the only 2 options, Or you could get a higher output stater and user lower wattage lights, but that option sucks! I think caps can be found on ebay for a decent price though. Quote Link to comment Share on other sites More sharing options...
Banshee109 Posted November 26, 2003 Report Share Posted November 26, 2003 i had the same prblem then i installed a ricky h.o. stator and and it makes the light a hell of a lot brighter then i went out to walmart and bout an offroad light kit for a truck made a braket then mounted those on my bars and hooked em up to te ricky and holy shit i can see forever...lol go with a ricky. Quote Link to comment Share on other sites More sharing options...
boonman Posted November 26, 2003 Report Share Posted November 26, 2003 I suggest using the clutch to keep the bike revved up a little for some light output, or you could downshift. or, you could use a capacitor, or a battery eliminator(same thing as a cap, actually, it is!!) but for 4-5 seconds, it would have to be fairly large. Or add a battery. A battery isn't a bad route, if you can fab the setup yourself. It shouldn't be more than about $100. Quote Link to comment Share on other sites More sharing options...
Skiddz Posted December 21, 2003 Report Share Posted December 21, 2003 I hated that very thing about my 'shee when I first rode it at night. My solution was pricey, but works great. Alba 260w stator and 4 Ricky Stator 55w Illuminator lights. I replaced the factory "fender" lights and added a Ricky Stator top clamp with light mounts and put two lights up there. Fender lights come on with the low beam setting, all 4 light with the high beam setting. They all come up to full brightness just barely off idle. The stator ran me close to $400 and the lights were about as much. Again, pricey, but worth it. Quote Link to comment Share on other sites More sharing options...
