Is This Worth The Money?
acracing55
***Patriot Racing mx kit*** 1,795.00
modify and reshape intake and boost port
modify and reashape transfers
modify sleeve
clean casting flows and coutour w/ transfer updrafts
modify and reshap exhaust
modify piston
install 28 mm. flat side carb kit.
crank shaft true welding
wiesco piston kit w/ bearings
aftermarket billet heads
after market domes
o'ring kit
v-force reed cages
billet timing plate
cylinder bore
performance gasket kit
seal kit
