cylinder bolts
Rommel
how much higher do u go on your torque to compensate for adapters
The adapters came with a sheet, that has a formula to get the correct torque.. it involves measuring the torque wrench center to center, and the adapter center to center.. then you plug those two measurements into the formula, and do the math.. im pretty sure with my torque wrench and the adapter, 22ft/lbs is 17ft/bs, but i always convert to Nm (Newton Meters).. because it's more accurate
