kryder Posted March 22, 2015 Report Share Posted March 22, 2015 I know this has already probably been covered so thanks in advance I notice my banshee leaks oil off of the front few bolts on the bottom of the case going up ward with little rubber seals. How do I stop it? I've tightened What do these bolts do exactly? Thanks in advance Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 23, 2015 Report Share Posted March 23, 2015 If I'm reading this right, I think your carbs are over flowing. There's a hole in the cases for a drain. Gas evaporates, and oil is left behind. Is there ever a puddle of oil under it after riding, and letting it sit? Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 23, 2015 Report Share Posted March 23, 2015 After reading it again maybe not. Are you talking about the lower engine mounts, or case bolts/ nuts? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 23, 2015 Report Share Posted March 23, 2015 (edited) Could even be spooge dripping. Clean the bitch real good and find out where it starts from. Edited March 23, 2015 by Larry's Shee Quote Link to comment Share on other sites More sharing options...
kryder Posted March 23, 2015 Author Report Share Posted March 23, 2015 I have cleaned it and it seems like it's dripping from the front three 12 mm bolts vertical into the case. These bolts have little orings on them as well. I will let it sit and it make a puddle the size of a nickle. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 23, 2015 Report Share Posted March 23, 2015 Pics? Is it 2stroke oil, or gear oil? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 23, 2015 Report Share Posted March 23, 2015 I have cleaned it and it seems like it's dripping from the front three 12 mm bolts vertical into the case. These bolts have little orings on them as well. I will let it sit and it make a puddle the size of a nickle. Pictures. Quote Link to comment Share on other sites More sharing options...
kryder Posted March 23, 2015 Author Report Share Posted March 23, 2015 Seems like 2 stroke oil because I use bel Ray gear saver in trans and it's not red. Il get pics tonight Quote Link to comment Share on other sites More sharing options...
