I went to little sahara in ok. Bike ran good in the morning but started to smoke as day went on!!! Got to were it looked like smoke signals behind me.. It's a 358 cub with 158 main and a 38 pilot bikes still rips and wants to pull wheelies in 3 and 4 th gear..checked trans fluid still full,, pre mix is 32:1 should I cut back on the oil a little bit ... I looked on here for a chart but have not been able to find it,, the jetting was spot on Jeff and Cody got the tune good on it!! Thanks for any help
Jeff and Cody from fast did plug chop on it when they worked on it,, and the temp went from about 42 to 75!!! A buddy came and checked compression and it still 151 in each cylinder as when the checked it
