Clamp my breather tube shut as well
You should not be building any pressure into the tranny or clutch area. If you hear air out the breather there is a leak.
Sent from my DROID RAZR using Tapatalk
Leak down FAIL! are you sure you had all your leak down componets sealed tight? if so, drain trans, pull clutch cover off, pull stator cover off and get ur squirt bottle of soapy water ready. do test again and start spraying seals and intake, and around the case halves in front, see where she bubbles,
That's gonna be tommrow its getting cold and dark out now. I cranked the freeze plugs in and used 5/16 hose clamps on the PVC with a 1/4" wratchet
That was dumb of me. The lower end would be pulling vacuum not making pressure.
Start over fresh tomorrow. Use a bicycle tire pump to build pressure up to 6 lbs then wait and listen.
Start diagnosing from there. Use your ears and the bottle of soapy water.
Did you seal your PTO side key and key way?
Its a good thing you took the time to do the leak down test!
  • Like 1
So if I take my dip stick out and put my finger over the hole and feel it build pressure I'm in trouble?
Yes.
Use soapy water in a Windex bottle and spray everything.
  • Like 1
When I took it apart I didn't see any kind of sealent, so I didn't put any on. Is it recommended to seal it?
