I am building a serval 392 and curr ently have toomey t5s. I am alil concerned about not having a big enough stinger. I am building it for trails and sand hill climbing and need a lot of bottom end but still want some good top end I don't see a lot of discussion About the stock stroke serval.
Thanks
Man, that's a tough one. Not many ppl go with a stock stroke serval. Also there has not been much in the serval with slp pipes.
I know the snipers are great on my serval and on 421 servals. But with that small of a serval I do not know how it will act.
What you do is you buy some snipers and if your not happy with them, trade them for some slp
  • Like 1
I think you're going to wish you had done the 421.
  • Like 1
I'm not a big fan of pipes that sign off early, I like over rev and pulling gear after peak power , every motor I put snipers on pull forever if you wanna hold a gear while climbing you can , slap is untested as far as I'm concerned a bunch of guys bench racing off dyno numbers, or be a test dummie
Thanks and I already bought the 392 I'm bout to put it together this weekend
Yea jeff from F.A.S.T. Racing hooked me up with the full setup and even did alil port work on the cylinders. I should have everything I need. I should be looking for mid 70s hp wise.
I would be surprised if it was much past 70hp, if Jeff did a bunch of port work I could see mid to upper 70s but most of the 421 servals with only a clean up port were only in the mid 70hp range
