sleeper06 Posted March 18, 2015 Report Share Posted March 18, 2015 I'll take em Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 18, 2015 Report Share Posted March 18, 2015 Haha, I'll pass. I've got enough engine parts laying around here. Shoot them to Carl or Cam. Quote Link to comment Share on other sites More sharing options...
registered user Posted March 18, 2015 Report Share Posted March 18, 2015 Camatv already spoke for em last night Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted March 18, 2015 Report Share Posted March 18, 2015 Lol allways a day late Quote Link to comment Share on other sites More sharing options...
984mmshee Posted March 18, 2015 Report Share Posted March 18, 2015 Ok RU Enlighten all of us here what a"good rod" is!! Im sure there is a few that would enjoy this knowledge. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 18, 2015 Report Share Posted March 18, 2015 He's gonna say pro-x Or custom made Quote Link to comment Share on other sites More sharing options...
sstaton1983 Posted March 18, 2015 Report Share Posted March 18, 2015 IMO....... stock rods seem to be pretty strong.. but anything is subject to failure when its pushed beyond its limits... like extreme compression ratios or bad tuning and maintenance. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted March 18, 2015 Report Share Posted March 18, 2015 The guy at competitive crankshaft said wsm were the strongest he's tested to date but there in the process of producing a new rod 3 mill thicker in certain areas , carillo will make you anything you want , they made me rods and Pistons to match s 7 mil stroker r1 engine I built n ported for a friend but your gonna pay close to 400 for initial machine set up plus the part but after that initial peice it's cheaper Quote Link to comment Share on other sites More sharing options...
registered user Posted March 19, 2015 Report Share Posted March 19, 2015 i see no reason to use a stock 110 rod except on a bone stock engine, in which case they will work fine. rods i use are 1mm thicker in the beam and quit a bit stronger on the little and big ends than even the grey hotrods, which have been known to snap in half. blame it on not cleaning the airfilter, not turning on the fuel valve, compression to high, blame it on what ever the hell you want but those are lame ass reasons for a rod to snap in half. if it cant handle some serious abuse it wont be installed in my engine Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 19, 2015 Report Share Posted March 19, 2015 i see no reason to use a stock 110 rod except on a bone stock engine, in which case they will work fine. rods i use are 1mm thicker in the beam and quit a bit stronger on the little and big ends than even the grey hotrods, which have been known to snap in half. blame it on not cleaning the airfilter, not turning on the fuel valve, compression to high, blame it on what ever the hell you want but those are lame ass reasons for a rod to snap in half. if it cant handle some serious abuse it wont be installed in my engineSo clearly your rods only come from Diesel engines. 1 Quote Link to comment Share on other sites More sharing options...
registered user Posted March 19, 2015 Report Share Posted March 19, 2015 naw theyre middle of the road but good enough. theres better ones but theyre $250 a pop. this game aint cheap. some corners can be cut but not on the conrods. its the weaklink in the chain, make it as strong as you can Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted March 19, 2015 Report Share Posted March 19, 2015 banshee cylinders cant make enough power to snap stock rods dummy Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 19, 2015 Report Share Posted March 19, 2015 Huh? Quote Link to comment Share on other sites More sharing options...
possum Posted March 19, 2015 Report Share Posted March 19, 2015 "Im only running 215 psi compression and backing plugs out". I dont know why my rod snapped. Quote Link to comment Share on other sites More sharing options...
registered user Posted March 20, 2015 Report Share Posted March 20, 2015 (edited) bearing for a support plate if anyone wants it, was sent with the plate. its brandnew. picked up a skf to use instead. just pay shipping probly be $5 or $6. right one in the pic is the one youll get Edited March 20, 2015 by registered user Quote Link to comment Share on other sites More sharing options...
