Hunter3473 Posted March 13, 2015 Report Share Posted March 13, 2015 Anyone know how to repair choke plunger that will not stay out? I took carbs off and there thoroughly cleaned inside and out but the choke plunger still will not stay out I have to hold the plunger out and kick. Not to big of a deal but would like it to work as it should. Is there a little retainer clip or something that holds the plunger in place when engaged? Quote Link to comment Share on other sites More sharing options...
Hunter3473 Posted March 13, 2015 Author Report Share Posted March 13, 2015 Here is a pic of the carbs there the stock mik's Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted March 13, 2015 Report Share Posted March 13, 2015 Take a picture of the plunger. I she o ring there or is the clip wore Quote Link to comment Share on other sites More sharing options...
Hunter3473 Posted March 13, 2015 Author Report Share Posted March 13, 2015 Quote Link to comment Share on other sites More sharing options...
Hunter3473 Posted March 13, 2015 Author Report Share Posted March 13, 2015 Is there supposed to be a clip or something on the grooves? Quote Link to comment Share on other sites More sharing options...
Motooutcastxxx Posted March 13, 2015 Report Share Posted March 13, 2015 Just buy a new one.. http://www.farmandsandtoys.com/partdetail.asp?partid=394 Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted March 13, 2015 Report Share Posted March 13, 2015 Do not buy a new one... pull the plunger, hold it with needle nose pliers, take a small file and file the notch. Quote Link to comment Share on other sites More sharing options...
Hunter3473 Posted March 13, 2015 Author Report Share Posted March 13, 2015 Which notch do I file? The ones underneath the spring or the bigger notch near the "handle" Quote Link to comment Share on other sites More sharing options...
Hunter3473 Posted March 13, 2015 Author Report Share Posted March 13, 2015 A new one is 40$ if it's a free fix I'll try that first plus I really dont need the choke but would like everything to work as it should. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted March 13, 2015 Report Share Posted March 13, 2015 There are 2 notches. When you fully extend the plunger you see them. Closer one to the knob is half choke, the further one is full choke Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted March 13, 2015 Report Share Posted March 13, 2015 You can pull the spring to one side, hold it with the needle nose and then file. Whatever is easier Quote Link to comment Share on other sites More sharing options...
Motooutcastxxx Posted March 13, 2015 Report Share Posted March 13, 2015 Thought they were a little cheaper than that actually, I just hold the choke plunger out if I need it.. But I will certainly try this fix out myself at some point! Quote Link to comment Share on other sites More sharing options...
Hunter3473 Posted March 13, 2015 Author Report Share Posted March 13, 2015 Trying to file it now I'll let you know how it goes Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted March 13, 2015 Report Share Posted March 13, 2015 You guys both owe me a dollar now. 1 Quote Link to comment Share on other sites More sharing options...
