n2otoofast4u Posted March 11, 2015 Report Share Posted March 11, 2015 Or.........live where you don't have to worry about it. 1 Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted March 11, 2015 Report Share Posted March 11, 2015 Well all of these should have dones isn't helping. I'm in Ks, but I'll still watch for it. A mor detailed list will be very helpful Quote Link to comment Share on other sites More sharing options...
vrx46 Posted March 11, 2015 Report Share Posted March 11, 2015 Or.........live where you don't have to worry about it.Crime happens everywhere no matter where you're at. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted March 11, 2015 Report Share Posted March 11, 2015 good luck bud hope you get it back. bunch of scum bags out there ill tell ya Quote Link to comment Share on other sites More sharing options...
toyotafan 78 Posted March 11, 2015 Author Report Share Posted March 11, 2015 Cub cylinders NOSS machine cool head Trinity stage IV 2-1 intake,port matched V force 3 reeds (little metal emblems on reed cages missing) Keihin pj carb Boost bottle modified from dirtbike,has hole plugged on left side,nipple moved,sits real tight against carb fmf gnarly exhaust,chrome worn real bad along sides,dull from boots rubbing. Both silencers are dented up on the endcaps Twist throttle + 4 swingarm that someone shaved all tabs off of (skid plate tabs,chain guide mount)so no chain guide Amp link "holeshot device" Home built a arms (+6 I think) they sit the shocks at an oddly steep angle,ball joints are welded in place. Stock plastics with all emblems and holes shaved,uncut,custom paint Monster energy seat cover,lines up with paint job on plastic. DG chrome nerf bars,little rust,with no webbing All stock water pump and clutch covers,just painted green. 14 tooth sprocket new holeshots on back +4 axle spacers in back Brand new,non o-ring gold Renthal chain (still white from the grease) Was missing: Mag cover Shifter Tie rods (custom length) One of the torque links/engine mount It's probably a lost cause,was not registered as I just recently bought it,and had a bent frame,so was in the process of swapping all to a new frame. Started hard,if it would start at all (carb issues) was just mocked together,nothing was bolted tight. Nothing really stood out,other than maybe combination of parts,and the paint. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 12, 2015 Report Share Posted March 12, 2015 That's definitely a quirky set up so it'll stand out. 2 Quote Link to comment Share on other sites More sharing options...
