Wondering if With brand new stock carbs that came with 200 mains. If switching from 200 to 300 would I have to make float bowl adjustments to let more fuel in. (Since I'm using more) mods are PC pipes no airbox and uni pods and tors delete. Chock tube is sealed. Thinking I have to adjust the tab on the floats. Elevation 500 ft. Temperature right now is about 40 degrees. Will be 60-70 in a couple months. Thank you
You can get a little more fuel in the bowls that way but you flirt with having excess run out the over flow. In all reality, you're probably more then fine just swapping the main jet. It takes a bit more motor to start sucking bowls dry. If you do find your self out flowing the bowl, you can actually get Billit bowls from Driveline Performance for a great price.
What could cause my banshee to cut out when I get to 4th gear then? Sometimes it won't do it till 5th or 6th
Is this with the 300 mains or the 200?
Gas cap vent could be plugged as well.
