trying to synch my carbs up I can get it synced up with the fast tool but the slides are pulling uneven by sight.... so i adjust them with out the tool (dead nuts pulling up at the same time) the synch tool reads diffrent from each carb what's going on here? did a compression and leak down blows 120 each hole and held 6 psi for 30 min
im wondering if one of the carbs is fudged i had a lean runaway 2 weeksback it passed a pressure check but hmmm. they are cleaned twice now may i should try a third time....
Lower the idle screws till there not effecting slide height, adjust cable play so each carbs pulling up at Sam time, then go to the sync tool , don't forgot to move idle screws back up before you start. Also don't forget to leave a lol free play at the thumb
ill give it a go i had a helluva time adjusting the slack in the cable i have so i bought a new one... are yfz450 thumb throttles different than the banshee ones or are they a plug and play? wondering if that might be adding to the mix with my cable issue
