prosite@live.com Posted March 16, 2015 Author Report Share Posted March 16, 2015 Could also be leaking from the head to side cover hose and leaking through the drain hole in case.You were right I noticed a leak from the head where it goes into the hose not sure if it's the oring or not tightened enough ... But wondering why would it leak from the stud at the bottom of the case (1 of the center ones) ? Since these studs are not going through the top case .... I know that tranny oil is inside the cases and the only place I could think of that would have coolant if the pump . But I have never split a case before so wondering what to look for .. Btw left side is smoking from the pipe and that's the same side that's leaking from the center stud ... Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 17, 2015 Report Share Posted March 17, 2015 My bet is that it is not leaking from the stud. It is leaking off of the stud. (Coming from farther up, running down and off the lowest point) -that stud. Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted March 17, 2015 Report Share Posted March 17, 2015 Do a leak down test again. .. let it sit for 20mins Quote Link to comment Share on other sites More sharing options...
