Clutch won't engage. ..please help
Hello, I simply changed the clutches cause I thought it was time since I ran the old ones for a year...ran just fine....all I did was change them, now it won't engage, just sits there when I let off the clutch. I even went back in and adjusted the eccentric screw so the actuator lines up with the arrow on the cases. Still nothing...please help, what else could cause this issue.
Yea. Did the steel ball get reinstalled?
Yes...never took it out...plus I checked to make sure it was there and it is. I was told that if the clutch plate is on correct, then u should be able to push the actuator and it would push the clutch out...which it did. Everything is lined up like the manual says and double checked and still NOTHING :-( :-(
Ok, well if thats the case and the actuator is moving everything properly, then its sounds like a broken or a not properly routed clutch cable. Is the clutch cable mounted securely in the case by the actuator? If so, if you grab the cable up by clutch lever, can you pull the cable out?
Actually I just put a new cable on....its not on exactly like the old one, cause there's a lil spot where the old one came from that i can't get to...and still with the old cable still did the Same thing. The cable works just fine....am I suppose to be able to turn the lockup and pressure plate when the clutch lever is out?
