oberlez Posted March 8, 2015 Report Posted March 8, 2015 Just wanting some ideas on what you guys think I should start out with for jetting. I race in Kansas and at the desert in OK. I have a 421 on alcohol with a k&t drag port, vf3's, 39 pwk with 10 inch filters, shear oof's. Any help would be appreciated. Again just wanting a starting point and so I can buy some extra jets that are in the right neighborhood. Quote
doctorwyant Posted March 10, 2015 Report Posted March 10, 2015 http://www.bansheehq.com/forums/index.php?/topic/133410-Banshee-Digital-Toolkit This should help you, it sure helped me. Quote
sleeper06 Posted March 11, 2015 Report Posted March 11, 2015 You can't buy jets for alky someone has to set carbs up , do you have a power jet installed already ? Similar set up by me is .1225 dump/ main, 55 pilot and egn needle 2 clip , big bowls one float cut off and some little circuits drilled a lil bigger start pj 6 turns out and go from there and squeeze it down Quote
sleeper06 Posted March 11, 2015 Report Posted March 11, 2015 Gas is 175-180 main to start , 52-55 pilot, dgh 4 th clip 11/2 on air screw Quote
