theputz Posted March 3, 2015 Report Share Posted March 3, 2015 I recently went from 35 pwks to 39s with new filters to match. My snipers were a tight fit before and now I cant see how I wont consistently burn air filters. I am considering going out of frame pipes but unsure as I do dune/trail a little as well. Any suggestions? Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted March 3, 2015 Report Share Posted March 3, 2015 Cascade heat wrap Quote Link to comment Share on other sites More sharing options...
Phelps Posted March 3, 2015 Report Share Posted March 3, 2015 rotate your filters where they slightly face out Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted March 3, 2015 Report Share Posted March 3, 2015 Ya good luck. Nice pipes. But clearance is an issue. What intakes are you running? Quote Link to comment Share on other sites More sharing options...
theputz Posted March 3, 2015 Author Report Share Posted March 3, 2015 UPP Intakes. Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted March 3, 2015 Report Share Posted March 3, 2015 Bout as good as it's gonna get I'm afraid. Quote Link to comment Share on other sites More sharing options...
BUILDER Posted March 3, 2015 Report Share Posted March 3, 2015 Header wrap from the parts house will work just fine or buy the cascade wrap either one will work. If you wrap them then it will not ruin your outerwares. If you ride trails I would not suggest going to out of frames but if you do please post pictures after your first ride lol Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 3, 2015 Report Share Posted March 3, 2015 My header wrap wears holes into the outerwears and filters. Quote Link to comment Share on other sites More sharing options...
gusto Posted March 3, 2015 Report Share Posted March 3, 2015 Putz, your bike turned out nice. More pics Quote Link to comment Share on other sites More sharing options...
srp Posted March 3, 2015 Report Share Posted March 3, 2015 Cutting 7/8" off of the filter spigot length will help the clearance on any brand of pipes. Also will help performance, the engine does not like any fixed diameter tube behind the carbs. Looks like you have more room between the frame and tailpipe than the test chassis did. I have some 1" x .400 spacers to space out the silencers, they will pull the tailpipe in closer to the frame for a little more filter clearance if you or anybody else with Snipers needs them. The spigot and reed block angle varies on aftermarket cylinders and even varies on the same brand from time to time. Just a degree or two will get the tailpipes into the filters or frame. Some thin pie shaped reed / manifold spacers would be a big hit with anybody running in-frames with fitment issues. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 3, 2015 Report Share Posted March 3, 2015 Bigger motor, bigger carbs, bigger filters, bigger pipes. SAME SIZE FRAME. Naturally the math isn't in favor of any banshee owner. Put some High Temp Fire Sleeve on there and be done. Quote Link to comment Share on other sites More sharing options...
srp Posted March 3, 2015 Report Share Posted March 3, 2015 Bigger motor, bigger carbs, bigger filters, bigger pipes. SAME SIZE FRAME. Naturally the math isn't in favor of any banshee owner. Put some High Temp Fire Sleeve on there and be done. True, but not many have filter fitment issues with any brand of pipes when the carb bowls are down close to the clutch arm. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 3, 2015 Report Share Posted March 3, 2015 True, but not many have filter fitment issues with any brand of pipes when the carb bowls are down close to the clutch arm.Agreed. Just takes the right combo of intake and filters. I still put fire sleeve on all pipes now. Quote Link to comment Share on other sites More sharing options...
theputz Posted March 4, 2015 Author Report Share Posted March 4, 2015 Thanks guys! Trimming the filters helped but still rest on the filter. Will continue to play around and see what I can up with. Quote Link to comment Share on other sites More sharing options...
theputz Posted March 4, 2015 Author Report Share Posted March 4, 2015 (edited) Putz, your bike turned out nice. More pics Thanks! Get some pics soon, she is almost done. Edited March 4, 2015 by theputz Quote Link to comment Share on other sites More sharing options...
