Flywheel key replacement
you can tap the flywheel on if you want but ive never seen the need for it. when the nut is torqed then you should be good to go. if not then maybe the key is in wrong or the crank snout is buggered up and not letting the flywheel pull up tight on the taper
 Which, is why you lap it, especially if it is a new/different crank or wheel. Takes a minute or two, then you know it's puuuurrrfect.
You get lapping compound from auto parts, with key out, smear on shaft, install wheel, with light pressure spin wheel back/forth or round/round a bit. Wipe shaft, inside of wheel. if both have an even "look" you're done. If not, repeat until you do. Clean it pussy clean before final assembly. Lapping will get you a perfect fit between the two.
If I knew why I can't copy/paste here, I would do a LMGTFY, haha.
Google might get you a better idea.
