4th gear powerband bogs
Wut up guys!! So finally got my bike all put together "4year build" and I've been trying to tune this monster every jetting I run is too lean "spark plug check" but today I finally got it into 4th gear and it bogged at 4th gear powerband... these are the Jets I tried and all the motor upgrades are on my signature...
1st set 142main 52pilot
2nd set 145main 55pilot
3rd set 148main 52pilot
All had needle in middle for fine adjust if needed and air screw at 1.5 turns out! This is a trinity set I called trinity and told them my setup and they recommend these!
Now I don't think I've gotten into 4th gear before but could the bog be from jets too big? If so why is the spark plug dry and charcoal? Shees running like a bat out of hell but guessing it's kuz it's lean?
I'm running 35mm keihen currently 58 main and 148 pilot needle clip on 6th position still dealing with lean conditions did a plug check it still looks a bit grey/charred and plugs are dry I been doing the choke on runs and the plug is still the same but wet... after I did the post I tried fully punching it and 4th didn't bog but 5th did! My take on it is if I'm not revving/speeding high enough then it bogs! But the power band should keep climbing? I don't have a leak down tester but when I first put her together I did have a leak it caused all kinds of issues but I redid everything retighten everything and the issues stopped... here's what's done to the motor..
400cub 68mm bore
Noss coolhead forgot the dome size but remember it's built for pump 91
ProDesign intake yes it has a boost bottle till I get caps
Billet reeds and 1/2" spacer
35mm keihen k&n pods
Barnet clutch basket HD discs stock springs lock out maxed
Cpi oofs
I'm assuming you meant 58 pilot. 148 main. And needle on 6th position, are you talking all the way at the top or bottom. Pretty sure there is only 5 clips on keihin needles.
None the less, dry and grey is lean. Give it more main, you should have more then enough pilot with a 58 in it.
OK I got pulled by the cops so I can't do test rides down the street anymore!! Haha I'm not fully fully rapping it up kuz I'm still in the break in process but yes yesterday when it bogged I slowed down "slightly" for a stop sign gave it a little go and shifted when I ran full it didn't bog on 4th but guessing did on 5th because I slowed down again! How many sizes should I jump at a time for the main? And yeah I meant 5th "bottom" of the needle for richness! I'm running it with the chokes on right now to keep it wet without its been completely dry through all the Jets I've been using!  Is the 58 pilot OK or should I drop it? The initial response from trinity was to run the 55 and 145..
This ^^^ is your problem.
As Tricked has mentioned, IF you don't get it jetted closer before you ride it you ARE going to hurt it. Riding with the choke on if it were anywhere close to correct jetting it would be blubbering like a short bus rider.
If someone with a simular setup doesn't chime in as to jetting, look in the thread "What jets are you running"
Also, post your elevation and riding temps, or where you ride, kinda specific area.
I only did the choke thing kuz I read up to ride with it on to see how much richer the jetting needs to be i.e. if it acts rich I don't need to upside but it's not the case.. I'm pretty much at sea level in San Diego been colder since the rain but not bad 70°f give or take..I'm gunnar have to bring the Jets with me and work on it when I head to superstition mtn on Thursday I'm gunnar put on the 158 I got if that doesn't richen it up I don't know then I might have to take it to somebody before I break sumptin!
