KINGKILLA Posted February 27, 2015 Report Posted February 27, 2015 Hey guys I have just bought a banshee an need a little help Ok so 2 days ago when I bought my shee it started first kick or 2nd kick the guy just had it rebuilt and had receipts an all so now I go to start it an it just won't start i can kick till my legs sore. I have put new plugs in an already changed gas. When I try start it in neutral clutch in it won't even make that blubbery sound while kicking it unless I give it throttle? I have been reading on here I'm thinking maybe it's a carb problem? Could the carbs being out of synch cause this because the slides raise at the same time but I notice when I go full throttle the ping marks in the carb windows go past the window on the side of the carb(they go abit higher) Are the ping marks suppose to be centered in the windows? When I bought it 2 days ago it started 1st 2nd kick do you guys have any suggestions thanks Quote
BUILDER Posted February 27, 2015 Report Posted February 27, 2015 First thing to do is see if you have spark at the plug then go from there! Pull a spark plug out hook the wire back up to it and lay it on the top of the head while you kick it over and see if it is firing then get back and let us know. No your carbs being out a sync a little is not going to stop it from starting Quote
sprinklerman Posted February 27, 2015 Report Posted February 27, 2015 Did choke tube fall off? Are you getting fuel for sure? Petcock on? Key on? Run/stop switch on? Quote
KINGKILLA Posted February 27, 2015 Author Report Posted February 27, 2015 Builder:I'm going to check for spark but what do you mean by wire like the plug rubber boot? Sprinklerman:the choke tube is connected in-between carbs an I key is on fuel is on Quote
sprinklerman Posted February 27, 2015 Report Posted February 27, 2015 Builder:I'm going to check for spark but what do you mean by wire like the plug rubber boot? Sprinklerman:the choke tube is connected in-between carbs an I key is on fuel is on Make sure fuel is flowing out of fuel line just in case. If temps have dropped, certain premix oils will gel and block the petcock. Quote
KINGKILLA Posted February 27, 2015 Author Report Posted February 27, 2015 Ok I have spark I noticed it's leaked gas sitting overnight an I accidentally left the tank on reserve Sprinklerman how should I check the fuel line should I disconnect it from the where it tees of to both carbs or disconnect them off both carbs an see if they run out both ends? Thanks Quote
BUILDER Posted February 27, 2015 Report Posted February 27, 2015 Okay so if you have spark as sprink said you need to make sure you have fuel. Where is it leaking from after you left the fuel on all night? I am guessing if it is leaking fuel then the float on one carb is probably stuck a it is loaded up on fuel. Might try turning the fuel off pull both plugs out and kick the bike over a good ten times or so then put the plugs back in and try to start it and see what happens Quote
sprinklerman Posted February 27, 2015 Report Posted February 27, 2015 ^^^^ builder like guys, but knows what he's saying about bangcheez. Have temps dropped significantly? Disconnect at tee is fine. If it flows from there, remove carbs ,one at a time and clean gelled oil mix from carb body ,bowl,and pilot jet. Use carb cleaner or wd40. Also , as builder noted, spark may be an issue. Make sure your spark is strong. Quote
BUILDER Posted February 27, 2015 Report Posted February 27, 2015 F you sprink give one dude and a handy and now I like guys what the hell?? Quote
KINGKILLA Posted February 27, 2015 Author Report Posted February 27, 2015 So I went out pulled the choke switched the key off an also the switch then i kicked it a few times switched the key on with choke out an she fired up..awesome I think it was def a fuel problem wonder why it started with that method though thanks guys Quote
ImSoBoard1 Posted February 27, 2015 Report Posted February 27, 2015 (edited) yep Edited February 27, 2015 by ImSoBoard1 Quote
BUILDER Posted February 27, 2015 Report Posted February 27, 2015 Doubt it is a fuel problem if it started after doing that. Guessing your kill switch or your key switch has a bad connection Quote
sprinklerman Posted February 27, 2015 Report Posted February 27, 2015 Doubt it is a fuel problem if it started after doing that. Guessing your kill switch or your key switch has a bad connectionHandy-man is right Quote
KINGKILLA Posted February 27, 2015 Author Report Posted February 27, 2015 Well after starting it it now starts up first kick now which is random but at least it's going..I couldn't help but take it for a rip down the street wow soon as I hit 3rd 4th gear hell fucking yeah is all I gotta say! Quote
BUILDER Posted February 27, 2015 Report Posted February 27, 2015 Well welcome to the addiction. Post up what all has been done to the bike and some pictures of it. Photobucket is the best way to post pictures on here. Quote
